what tool did you use?khoerling said:The head of my idle screw cracked off after trying to adjust it.
Am I screwed? (forgive the pun)
k.
Are you sure it was the screw head? It sounds like it might have been the wax cap over the screw head. I had worked mine with plenty of tourque with no problems.khoerling said:I used a flat-head screw driver, and the head just cracked off.
Now, the adjustment screw is flat on top.
k.
If you would please! thanks! :****: you DA maN! :****:MikeD said:Oh please never when your car is off. Only during Idle. After warm up the engine, the idle should be in range of 650-750 rpm for an Automatic (subtract 50-70 rpm for a Manual). Do you know how that works? If not, I can post you the complete steps incl pics. There are 2 ways to get a proper Idle. -Mike
