LATIN_RAVER_LEGEND said:
If a mast is around $50, than isn't it cheaper to a new antenna from ebay?
http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=1804486874&r=0&t=0
R these not good? I was going to replace my mast cuz my antenna wont go down the whole way. Thanks.
Latin...................
You've probably already tried this, but I thought I'd suggest anyway....
Did you try putting some grease or wd-40 on your antenna? Many times it doesn't go down all the way just because it isn't lubricated enough...
Good luck,
James
Re: Re: If a mast is around 50, than isn't it cheaper to.......
Good luck,
James
I tried James, but nope. It still makes a clonking noise when going down. I'll try putting some more wd40 on it but I also heard that when u do that u also run a risk of gettin junk stuck to the lube and than it goes to the motor, but if u think about it u might need a new whole antenna so u might as well give it a try :D. Thanks.
Latin......................
