1 - 8 of 8 Posts
When was the last time any of you replaced your coils? What did it cost?
Have any of you had to replace your ignitor? Is a defective ignitor easy to notice because the tach bounces around ? I know my integra ignitor was going out when this happened.
tagup4mnce said:
I got lucky and found 6 coils on ebay. I won them for around $130 shipped. Good luck.
I guess $130 is worth the risk of buying used coils that may not work...
There is a test procedure to check if your coil is bad. The resistance between the #1 and #2 pis on the coil (the bottom two pins) should be 1ohm +/- 10%, or .9-1.1 ohms at 77degrees (which is obviously at room temp and not just after driving around).
So I tested my coils and theyre all about the same, even the new one, so its harder than described to tell if a coil is bad or not. Its easier to drive the car and tell that the motor is misfiring instead :p
1 - 8 of 8 Posts
