Incredible Spring deal
2.5K views 31 replies 15 participants last post by  Gerald
Aight, heres the deal fellas. I spend 2 hours last night talking to a guy named Randy Saucier. Those who do auto-x know who he is. Runs miatas in SSB class. He sets track records for his class regularly.
He has a guy who custom makes springs.
he said for $55 a spring. (do the math 220 a set) he will custom build them for me and as many as i can sell
There will be no group buy.
Some of you look at this and say so, its about the same price as eibachs. consider this
1. You can custom order your spring rates. If you wanna race, this is perfect for you.
2. You can custom order your drop. you wanna slam it 3 inches. it can be done.
3. All of you Show guys can get them powerdercoated whatever color you want. all for the same price. Yes, the price includes powder coating.
Who is interested?
and if you are one of those **** that says, yeah i want some to everything, and never puts any money down. your post will be ignored.
#29 ·
ScotcH said:
Are these progressive rate springs, or linear? Keep in mind that linear is great for race, but sucks on the street, and vice-versa.
Also, as a point of reference, here are some rates (lbs/in):
stock: F=~220, R=~150 (prog)
Eibach: F=~280, R=~180 (prog)
Okay. I have a question on this topic. I put eibachs on my ride back in August and took em off a little over a month ago due to the stiff ride. If I were to order a custom Eibach prokit with stock spring rates, it would feel just like a stock ride, correct?
At this point of time I am have stock springs and Koni's which in my opinion is a very comfortable ride. I am lowered just a tad, but nothing major. When I took tha eibachs off, tha rear sits tha same as it did with em on. I only notice tha difference in tha front gap. I'm just curious about this topic at hand.
Peace
#30 ·
I'm not sure that will work very well. If you shorten the spring (lower) and don't increase the stiffness (lbs/in), you might be hitting the bump stops over bigger bumps. The way the spring rate works is how many inches a given mass will compress the spring ... since your car's mass does not change, and since you want the OEM rate, it will still compress the same amount as a stock spring. However, since the spring is about 1.5" shorter than stock, you might run into problems with bottoming out. Does that make sense?
This is just all speculation of course, based on my limited suspension knowledge :)
#31 ·
It kinda makes sense. But see, I do even have bump stops at all. When I was goin' through my "suspension stress", tha head mechanic at tha dealership said that u really don't need tha bump stops in. I can't remember exactly how he worded it though, so I can't go into detail with it. But I have been without bump stops for tha past 4 months and have never bottomed out, even when I was lowered on eibachs.
