1 - 7 of 7 Posts
IF its just like installing regular OE (North American)headlights then no problem then, but thanks!
if not please give me the details that I need to know!!!
thanks
What?
I meant staying with the bulbs I got now, just adding the headlight for style!
or did you mean something else?
What do you mean?
I am new to this so please be paitent and explain?
IF not 9006 then what?
thanks for the feedback!
Re: What do you mean?
What I mean is the US Legends headlight bulbs are 9006 style while the 1 Piece headlights use H4H bulbs which are totally different than the 9006 bulb.
fyi, custom work is required. have it installed professionally if you don't want to put yourself in a jam. it's not like usdm oem headlights. you have to splice wires and connect them properly.
usdm
9006 - low beam only
jdm
h4h - low and high beam (bulb is exactly like usdm h4 but have a bigger neck for the place of the bulb. it's possible to cut the metal off the h4 bulbs but i doubt you will be getting into that.)
1 - 7 of 7 Posts
