1 - 11 of 11 Posts
it could be the alternator not charging the battery, since you have a new battery, when my starter went out, it would just click once and i'd have to crank the key 7-8 times before it would start, but when my alternator went out my car would click like crazy, hope that helps
Try jumpering the battery with a good battery if the car starts then you need to check your alternator or charging circuit. If the car does not start and still clicks then your starter is bad.
Could you have the same problem that i'm having?
I'd say that if you jumped the battery and the starter only clicks then it is most probable that the starter is bad. The contacts in the starter solenoid is bad and is not making the connection to energize the starter.
1 - 11 of 11 Posts
