21 - 40 of 66 Posts
lDneGeL said:
ic, so i have the factory one. well they werent that hard to install and i polished them up so they look pretty good. some guy sold ka7 airbags last time on ebay, takemorepills bought it i think.
hey IDneGel what kinda sideskirts and lip is that???
---anyone have some good pics of these visors??
Yup...
If the weather's not crapola this weekend, I'll throw up some pics of the visors, grille & emblems. Don't have the sidemarkers installed yet, so no go there. Be patient, grasshoppers...
Got 'em...
Go here for pics of the visors installed. These are some pics I made back in the spring when I got the original visors installed using #10 screws and lock nuts to hold them on. I now have 3 of the replacement visors installed (waiting on the last one to arrive from JRock) and will get some pics of those, if anybody wants. I'll try to get pics of the JDM grille & emblems today since it's quit raining. Holla---
Re: Got 'em...
im confused so the factory installed had screws? or did you make the screws? i kno i asked before but whats the difference between the replacement and the factory. i thought i had the factory.
They will look just like the sunroof visor in apperance and color.
Roger said:
so does someone have actual pics of the visors that we will be getting , the ones stevieray posted look good im not a fan of the screw. The ones lDneGeL posted dont look shiny at all or transparent ??? so which ones are they?
mine need to be polised i have polished only one.
Re: Re: Got 'em...
You do have the factory installed ones. My question is how in the hell did you get the clips back behind the window run channel while they were still attached to the visor? I tried every way I knew to get them back there and when I did, there was no room to work to get the run channel back in properly. That's why I ended up cutting the clips off with a Dremel and putting them back on with the #10 screws. I figured the factory had some special way to install the visor and then the window run channel since the replacement visors have the clips & pins separate from the visor.
I finally got my last replacement visor from JRock yesterday so I'll install it this weekend and try to get some pics up. The replacement visors are a much cleaner install, IMO. Later---
Re: Re: Re: Got 'em...
the visors are just like window trim, i had experience with the rear window trim because i had to replace mine. so i knew all i had to do was pull the channel all the way out and pop in the visors.
21 - 40 of 66 Posts
