UPDATE - Started on the project today!
Today I finaly had the time to start the project and got quite a bit done!
Breakdown of what I have done:
1. Removed all wire harnesses, bulbs, clips, etc. and baked the headlights. 2. Removed main headlight glass diffusor and the main headlight reflector.
3. Cut the reflectors to fit projectors. Fit the projectors in and made a few more extra minor cuts until they fit in perfectly the way I want at the right angle.
4. Mounted reflectors back into headlight assembly to properly and accurately position the projectors. Marked the reflector at 4 points where I will be drilling holes to screw the projectors to the reflectors.
5. Fitted shrouds onto projectors while in headlight and marked where the shrouds needed to be trimmed.
That's basically where I stand now and only have the following left to do:
- Remove reflectors from headlight assembly and drill out the small holes.
- Trim shrouds.
- Mount projectors to reflectors with screws which I will get from Home Depot.
- Clean out the inside of the headlight assembly and prepare for re-assembly.
- Re-assemble and re-bake the headlights to seal them up again.
- Put all parts back on again.
- Prep wiring for connecting.
- Wet-sand/polish headlight surface.
For those that have baked their lights, how easy is it to seal them back together and do they seal perfectly such that moisture doesn't get in?
Also a word of caution to everyone who wants to do this, I ed up slightly when baking them, I followed one person's instructions on the forums to put aluminum foil on the oven rack and placed the headlamp directly on there... well let's say I got some lines on the corner of my headlight that match the lines you get on your steaks when you grill them
I'm so lucky it was on the very corner where the hood will cover it and should not be noticable. A nice set of fibreglass eyelids will definetely cover them. I didn't have a cookie tray so I put an upside down baking pan in there which worked perfect on the next headlight. Other than this, everything has been flawless and am looking forward to completing this during the week.
Dave, I may need your help with removing my bumper since I know you've done and will make my life easier.
More updates to come.
