61 - 71 of 71 Posts
Discussion Starter · #61 ·
Thanks for the compliments. I remember at first when I saw the first brave ones to undertake this project, I thought holy shit how hard it must be to do that. However after reading a few DIY and really thinking about it, it's not that hard, just have to be a little creative and good with tools.
Also an update, I had to take 1 headlight appart again. It fogged up when I washed the car and in the recent weekend of rain we had, it had a tremendous abmount of dropplets on the inner lens. The next day I removed the headlight from the car and stuck it in an oven again. I cleaned the inside lens up and polished it up, re-baked the light this time squeezing hard hoping to make a better seal. In the end just to be sure I applied an all purpose outdoor/indoor clear sealant around the entire seam of the headlight as extra protection. I will be washing my car today so I'm crossing my fingers it is sealed.
To answer a few questions:
Octane - Let me know when you want to do yours.. i'm ready :D
GreekPower - efxaristo yia ta logia sou ;)
khoerling - Months ago I ordered a set of OEM civic foglights to replace my OEM fogs (exact same thing) as the glass lenses on mine were badly scuffed up. Well this civic kit came with a good wire harness to hook up the fog lights so I used that harness for the JDM fogs. I cut off all the wires I didn't need since I wasn't going to use their switch as I had a switch of my own to use which I ran into the centre console under the arm rest. I wired this harness to get power from accessory so I don't accidently leave the lights on and what's cool is I can turn them on independently from my other lights. Looks pretty cool just driving with the JDMs on. Hope this answers your question.
KeithQNguyen - Are you still looking for the diffusers? If so, PM me.
Discussion Starter · #63 ·
GreekPower - I don't type enough to know what English letters to use to make the proper sounds.hahah.
khoerling - I actually took it directly from the fuse panel by the kick-pedal. There is an aux. accessory and an aux. battery (always on) plug in there.
QUOTE]
Go to home depot and get butyl rubber. It's the same stuff that' used to seal your headlights.... Works great! --=Keith
rayhk said:
Here is my Tsx retro into usdm headlight with the same E46 shrouds as yours. I finally solved the cutoff distortion problem by swapping the lens made by Depo into the headlights. Depo makes very nice and mint lens with no optical distortion at all.
Ouch...thoseare amazing!!! Those are the sickest shrouds I have ever seen too...i'm hoping to do the same next spring.
Hmm... where I work, we design and test automotive headlamp and taillamp assembly's, and me being the person on co-op, I usually have to take them to our other building and destroy them. Maybe I will grab myself a few projector's next time...
61 - 71 of 71 Posts
