there was actually a factory G1 sedan turbo...if you believe that
specs:
LEGEND Ti EXCLUSIVE V6TURBO MODEL DATA
Item
Specification
Engine 2.0 L V 6 24-VALVE+PGM-F1 < TURBO >
Type V 6ti EXCLUSIVE
Car name * type HONDA * E-KA5
Transmission Full electronic control (PGM) 2WAY 4th gear automatic
Total length (m) 4.690
Full-width (m) 1.695
Total height (m) 1.390
Wheel base (m) 2.760
Tread (m) before / the rear 1.475 / 1.455
Roadspace (m) 0.150
Vehicle weight (kg) 1,420
Riding in a car fixed capacity (name) 5
Size inside passenger compartment (m) length / width / height 1.945 / 1.435 / 1.125
Engine type C20A (turbocharger attachment)
Engine type * number of cylinders Water cooling V type 6 cylinder horizontal ranging (unrelated premium gasoline specification)
Combustion room type Pen To roof shape
Valve gear SOHC belt driving inhalation 2 exhaust 2
Entire aerodynamic volume displacement (cm 3 ) 1,996
Inside diameter / distance (mm) 82.0×63.0
Compression ratio 9.0
Fuel feeder type Electronic fuel injection system (HONDA PGM-F1)
Fuel pump type Electromotive system
Fuel tank capacity (L) 68
Lube capacity (L) 5.5
Lubricating system Force system
Ignition device type Full * transistor type battery ignition
The highest output (PS/rpm) net value 190/6,000
Largest torque (kg-m/rpm) net value 24.6/3,500
Fuel consumption rate (km/L) 10 mode travelling 8.8
Fuel consumption rate (km/L) 60km/h fixed area travelling 16.9
Minimum turning radius (m) 5.5
Braking braking distance (m) time of initial velocity 50km/h 14.0
Clutch type 3 element 1 step 2 phase shapes (lockup clutch attachment)
Transmission type Regular gearing shape
Transmission operation method Floor * change system
Speed change ratio 1st gear 2.764
Speed change ratio 2nd gear 1.500
Speed change ratio 3rd gear 0.972
Speed change ratio 4th gear 0.707
Speed change ratio 5 speed -
Speed change ratio retreat 1.904
Deceleration ratio 4.714
Leader type Rack & pinion system (power-steering specification)
Tire (before / after) 195/65r 15 90H
Type * type of main brake Before the vacuum boost ceremony: After the ventilated disk: Hydraulic type disk
Actuating unit and braking wheel The right 1 wheel of 2 systematic ceremonies ago - the left 1 wheel before the rear left 1 wheel - the rear right 1 wheel
Braking effort control unit type Proportioning device (skid control)
Suspension system (independent suspension) Double wishbone system (before / after)
Stabilizer type Torsion * bar system (before / after)
