Hey Guys.. I just discovered my legend has the OEM keyless entry system installed in it but no remotes came with it when I bought it. Wanna get some remotes for it on e-bay but I called the dealer first. They said the remotes on the OEM system are not programmable and I need to get a new one with the same serial number stamped on the receiver mounted inside the dash. The remotes are available only thorugh acura. Has anyone dealt with this before? Do you know if it's true that this remotes canot be programmed? That means if I buy a used one off e-bay is a waste of money. Any advise will help..
