Struts = Shocks / Shocks = Struts
Same difference
Don't worry we all say strut or we all say shock (depends how we feel)
If you bought koni's for a 91-95 legend then don't worry as there is ONLY 1 application for our car. Sedan or couple they are the same as long as they are from 91-95.
As for the Ground Control "coil over" make sure they have the Koni add on or you are going to have to buy them from Ground control or make your own. Basically Koni's are about .03inches smaller than stock struts(or shocks
) and they have to add a metal ring on the inside of the coil so that they fit properly on the koni with very little (probably none) movement.
Good Luck and enjoy that 3 inch "SLAM" on factorys - I know I am
, but now my tires look like /-------\
and I am too poor for a camber kit right now
