Well I have mine installed ( :) ). But I have a concern/question. I have the spring tension pretty tight aswell as the shock shortened. When causing more tension on the spring how does that effect the ride? Does that affect the bounce or is that the dampen knob? Thanks for any help I can't wait to adjust them properly.
I shortened the suspension so the car will sit lower. I just have the ksports for a setup. I guess I need to loosen up the springs a little see if I can get a little bit of a softer ride. I assumed they should be as tight as possible with hand power.
