1 - 20 of 50 Posts
Soon to be BOOSTED!
Group Buy!! G2 Legend Specific Ksport Kontrol GB...$760 shipped....ROUND 5!
I have received many PM's pertaining to interest in another Ksport GB so here it is.
As of now Ksport is well stocked with the Legend Specific Suspension system so their should not be any problems in terms of a expected delivery date once we get the 5 buyers needed to have another succesful GB.
There is plenty of information available on this forum that will help you learn about the suspension system as well as the pros and cons.
Here is a brief description of what the set-up consists of....
Ksport Kontrol Pro Coilover suspension system!!After doing some home work I found a distributor that can deliver a set of Ksport Kontrol Coilovers for $760.00 shipped to your door! However we will need a minimum of 5 buyers, which really is not that many at all for a GB that can get you the Ksport system for almost $100 cheaper than the other guy.
This kit retails for $1200.00! So get in on this GB and save a ton of money!!
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Many members here on the forum are using the Ksport Kontrol suspension system and they love it. I have herd great things about the suspension and as you will see from doing your own research here on the forum, they have gotten great reviews.
Key Features:
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
Here are some testomonies from previous buyers..
http://www.acura-legend.com/vbulleti...d.php?t=105033
http://www.acura-legend.com/vbulleti...ghlight=ksport
I will request that we start sending payment when we have met the 5 buyer mark, so until then post up here and let me know if you are in on this GB.
The GB end date is May 1st 08, so please get your chips together by then. in order to complete this GB we will need a minimum of 5 buyers.
1) 97 LRer
2) FramaQ
3) ConKhi
4) Oscarav
5) gt2pla
6)
Ultimate DIYer
I'll be the first to try G2 Legend Ksport coilover to G1 RL! I'll have front forks from G2 Legend to resolve front strut fitment. Anyone who can willing to sell them at cheap price, please pm me.
TEXAS PSYCO
Is there any way to set these up where it doesent destroy your kidneys? I have been looking into dropping and i know these give you ultimate control over height but can you set them up so they dont kill you ass for a daily driver???
Ultimate DIYer
Read my thread. I had collected Ksport testimonies in the thread. Ksport coilover is the top performance wise yet comfortable.
http://www.acura-legend.com/vbulletin/f29/opinion-needed-ksport-coilover-owners-1st-gen-rls-120768/
Soon to be BOOSTED!
Discussion Starter · #12 ·
Now that we have 5 potential buyers, I will send out payment instructions on Monday. Once all 5 payments are received, the suspension will then be sent out to those buyers.
Excellent!!
how much are the 5 thinking of lowering? inch/wheel/tire combo? it is looking like 18's for me. then lowered to get rid of as much wheelwell aspossible without rubbing and not dragging on speed bumps. i've never had a lowered car so no exp. but i sure like the look. and out to the edge of the car.
Soon to be BOOSTED!
1 - 20 of 50 Posts
