1 - 11 of 11 Posts
· mods: yes PLEASE!!!!
Im in the process of making custom LED lite door sills and have almost everything done but the LEDs and the wireing My question is how to wire these, I was planning on either running them to the door lights that turn on when door is open or have them run to the headlight switch or there own switch. Theres a kit on ebay I was thinken of getting that is made for car applications but I havent bought it yet. I have also checked out legendtunner for there DIY headlight mod but i need to know where wires are inthe car and picture WILL HELP ALLOT!
ANy idea on how or where to wire the leds too???
btw ill be makin a DIY for this project and or will ba able to take orders ( nto sure tho on the orders)
bl420 said:
i would wire it with a relay to the door trigger... that way whenever you open the doors it will light up
thats wut I was thinken but the kit on ebay im thinken of getting has a swtich ( which i can use or not) but i would perfer the door trigger
just wire it to your dome light, as far as wiring leds it depends on what kind of job you're doing. all leds will require a resistor to guage amount of current running to them. ive done a crap ton of small projects with leds so if u have any questions just pm me. but yeh i would have it come on when u open your doors, if that is the choice you take then wire it to the dome light
where can i find these dome light wires???? i also have my manual open but its not showing where they are
· EDM Honda Legend Coupe
Exactly ! I'd do the same. Here's the Main Door Trigger Connector (Minus controlled !!!). It's located behind the lower door panel above the hood release. I did the same for another reason so I decided to make a seperate dimmer light for the inside the center console armrest box. Works great and easy to do that. Just a thought ;) -Mike
BE CAREFUL! IT'S NEGATIVE CONTROLLED
Discussion Starter · #11 ·
arright ill lookk for that but im jsut doin 4 lights and they wont be on all the time but an d i was thiken of just hardwiring
1 - 11 of 11 Posts
