For the coupe: The brake lights are dual filament 1157 bulbs, the turn signal and the backup lights are single filament 1156 bulbs.
For the sedan: The bulb at the top portion of the taillights is 1156. The backup and turnsignal are 1156, the 2 brake lights at the bottom of the taillight portion are 1157. Then there's also another small 168/194 bulb in the bottom corner of the lense where it wraps around the body, it lights up a reflector inside the housing so it can be seen from the side at night. The coupe doesn't have it, because coupe has a rear sidemarker.
