1 - 8 of 8 Posts
These days I have a problem with my Legend 92. The engine usually off when I was driving, I can't turn the engine on, and D4 light was not on too. But if I try to turn off and on the key for many time, when D4 light on, and then I can turn on the engine.
I went to Honda service to fix my car's problem but they said it do not have any problem. I thought Honda service in Vietnam can't solve my problem. So, If anyone know what is my car's problem and how to fix it, please help me
Thank you in advance!!!
how can the car be off while ur driving??!?!?! :confused:
Yes, it could happen and it can happen. Intermitent contacts in the ignition switch only require a low shock level when the vehicle is in motion over a bump or a pot hole and it can happen in a blinking of an eye, all of the sudden the electrical power is off and back on again and so on ... I had it happened once when I came home from work before, anyway I did replace mine after that and so far so good.
I check my ECU code, and I saw 1 long and 5 short flashes.
Please tell me what is it error? and how to fix it.
I'm living in Vietnam, Honda Vietnam can not help me to fix it, I must do it by myself, but I don't have muck knowledge about car, so please help me for detail
Thank you!!!
Code 15 is the ignition output signal. There are a couple of possibilities in wiring but one very likely culprit is the igniter and the other is the ECU itself. If you can find an igniter from a junk yard etc. that would be the way I would go.
ive had similar problems after i installed a new head unit.
I figured it was one of two problems, the battery (dvd head unit uses a lot of battery power), or because i had pulled on some of the wiring connected to the shifter and may have scewed up a aconnection somewhere.
I recharged the battery and refilled the battery cells (they were low)
and pushed the center counsel in a little harder (to fix any loose connections?? i dont know it made sense at the time)
and its worked ever since then
1 - 8 of 8 Posts
