1 - 20 of 95 Posts
GREYLEGEND
Discussion starter · #1 ·
Hey, lifter tickin thing is driving everybody crazy.
Remember there's two possible reasons for the lifters not to work properly ( They're also called HYDRAULIC TAPPETS).
A. Not enough oil flow and pressure getting there. Auto-RX will help there, and
B. the other reason could be maybe they're not sealing properly and won't hold pressure. Auto-RX can't heal a worn out lifter.
Check here: for a better concept.
Page 5-25 or 7 of the PDF document
http://www.honda.co.uk/owner/LegendCoupe/62sg000/5-20.pdf
NOTE::::: the first step is to check for damage "for wear or damage or for a clogged oil hole."
When we Auto-RX we're hoping for a clogged oil hole that sludge might have blocked and Auto-RX to help dissolve and clear it.
IF there is wear and no clogging, then Auto-RX may or may not help the situation with respect to noise.
How can we help the situation if there is wear. 1. Use a thicker oil/ heavier oil. This will help allow the lifter/hydraulic tappet to develop more pressure by having less leakage.
Now if you think about this carefully, you'll understand why some people report that using 20w-50 helped their situation and some people report that 5w-30 helped theirs. Total confusion.
Now if you have ticking, understand this. If the ticking is due to a clogged oil hole and you use a thicker oil. You could end up doing more damage. Why? oil is not getting where it needs to get to and you'll eventually end up with situation B. - worn out lifters and further clogging.
So if you have ticking, here's what I recommend. Try the Auto-RX routine or some other safe sludge cleansing routine that gets deep inside and hope it goes away. If it does, you had a clogged oil hole and you've cleared it. If after two tries with Auto-RX and it does not go away, I say try a heavier oil.
Now Steveman recommends that Friction free stuff. That stuff is supposed to have small metal particles that "coat" walls. I can see it possibly working in situation B. Where the lifter are worn and can't hold pressure it may help develop a better seal However, I can also see if it was a situation A where there was clogging, then possibly it may do more harm. - It does not clear clogged holes.
I think no matter what if you have ticking I would tend to recommend a treatment of some type that cleans and clears out sludge first as that will cause no damage buy rather help overall operation of the engine. If the noise does not go away try a heavier oil or Steveman's recommended product.
The only surefire, but expensive way is to replace all the lifters - 24 of them by taking the head apart. So take your pick and remember once you get rid of the noise, always keep your oil in good shape as that was the cause of the noise in the first place.
i think that this thread should be stickied and we need to put an end to all of these lifter threads, all questions should go here
grey, you know my situation, so after what you've said, i believe that i have a worn lifter or two (based on the amount of ticking). i ordered 2 bottles of steveman's recommended product frictionfree 3000 (ff3k) and i'm going to be running it for the first time w/ pennzoil 5w-30.
my question is, for situation 2, do you recommend running a heavy oil alone, or a light oil w/ frictionfree 3000? which will help preserve the engine and what costs do u figure for each instance? also, if its better to run ff3k w/ a lighter oil, would it be worth it to run german castrol 0w-30?
just tryin to explore some options
thanks
Discussion starter · #3 ·
you were getting good results with Havoline 10w-30. I say stick with it, it's an excellent oil. There's really nothing wrong with using 10w-30 in your climate. The trouble with Pennzoil for you is that it is one of the best flowing dino oils at low temps. That naturally means it is on the thin side . Also High Mileage oils are on the thicker side, so those may help too.
There's a trend in your case... thicker oils have helped (10w-30 and GC 0w-30) so you're likely a situation B. See what works for you and just keep your oil in top shape.
Discussion starter · #5 ·
Ticking only on startup, I would suspect Situation A... clogged port or passages. A worn out oil pump may aggravate this too.
Continuous ticking..... probably worn out lifters... try out heavier oils. That's my guess anyways.
What someone should do is start a thread and see if in fact it confirms my hypotheses. For example using seafoam and queting.... clogged port. USing restore ( also metal particles) ... worn lifters. Using FF3000 worn lifters. Using a thinner 5w-30 .... clogged ports.
alright. i am feeling good about havoline 10w-30, but I think I want another go with the german castrol to see how good it is (and if its any better than the havoline w/ my situation)
FYI for people that think they are experiencing what I am-
• I've ran 2 auto-rx treatments so far
• I've tested Restore and it didn't completely quiet my lifters
• Pennzoil 5w-30 gives me lifter tick constantly (a few lifters stop ticking after warmed up, but several remain)
• Havoline 10w-30 was run during my rinse phase of my 2nd treatment of Auto-rx, and near the end of the rinse phase I had almost no ticking when warmed up and no immediate ticking upon starting the car
• German Castrol 0w-30 worked well after my first Auto-RX treatment and I will be using it for my next oil change to see how it does after 2 treatments (I have high expectations :))
• I have purchased 2 bottles of FrictionFree 3000 as Steveman recommended, they haven't yet come so I do not have results for them. First bottle will be going in with my Pennzoil 5w-30, and if they quiet my current continuous ticking, I will definitely recommend the product to anyone who suspects worn lifters.
today it was 80 degrees here in NC, but it felt a lot hotter, and my lifters were quiet on my ride to work (first time since my oil change)
is having quieter lifters in hot weather a sign that i have lifter wear for sure?
Actually Zoom...I would think that having quieter lifters in hot weather would mean Situation A with the clogged ports....as would the opposite (having noisier lifters on a very cold day) The reason being that in very hot weather, the oil would be flowing faster in the warmer than usual weather...making it easier for the oil to get into the lifters...and in very cold weather (where the engine and oil may never fully reach normal operating temp) the oil will run slightly thicker and may not be able to adequately lube the lifters.
Here's something I did...for some reason, my lifters have been total bi@tches since my last oil change about 1500miles ago. I had finally had enough...I bought some Seafoam. I had my hesitations about using in on my engine though. So I ended up putting it into the Brake Booster vacuum hose to the intake...followed the instructions from here on the forums and now my lifters are DEAD SILENT even on the coldest start-up...I didn't put any into the crankcase nor any in the gas tank...just the intake. And I ONLY USED 1/3 OF THE BOTTLE SO FAR...It may not work for everyone's car but it did silence mine!! I am no longer embarassed to leave a parking lot in front of large groups of people (especially the ladies!)!!
Discussion starter · #13 ·
sam I'm not denying that seafoam made the engine quiet but the intake does not see the lifters at all. Maybe the noise was something else that seafoam dissolved and the noise was not the lifters at all. That's what it sounds like. Maybe there was carbon buildup in the combustion chamber, valve seats?? Maybe it was coincidental as when you put the stuff in, you revved the engine up? and cleared a port with the high oil pressure??
I have pondered that also....but the thing is that my ticking was textbook ticking from the G1 Engine...my mom, stepdad, and aunt all used to have G1's so I do recognize the noise...however, it seems that the Seafoam has definitely cleaned "something" because it was w/o exception that every morning I would start the car, it would have REALLY bad ticking until it wamrmed up...then throughout the day it would tick at start-up but eventually quiet down with engine temp (w/o ever really being completely silent). NOW the ticking is completely absent...at first cold start-up in the morning and all day and all night...completely silent engine bay....its pretty nice! Whatever it did I'm completely happy with it....
I am trying to get rid of the lifter ticking in my car but I quite like the ticking, it says to me you own a Legend. If it is quiet it sounds like verybody elses car :D . However I am not keen on the engine rattling away when driving past friends. :giggle:
Regards,
Steve
Love to Love the Legend
GREYLEGEND said:
These days everybody's thinking fuel economy and hybrids or DIESEL.
Go to the salvage yard, get some DIESEL or better yet TURBODIESEL labels and stick them on the G1. The ticking???? It's a diesel that's why!!!
excellent idea! might as well pop some vtec labels on too.. diesel vtec = mad hot
i did the seafoam thing tonight though! the brake booster vacuum hose has some mad vacuum on it :p sucked up half a bottle quick. ticking is still there when warmed up but i can't hear the ticking on the interstate or during acceleration or anything :2cool:
the frictionfree 3000 should finish off my ticking!!! I'm very excited.
my ticking came soon after i purchased the car. i did one oil and oil filter change (20 w 50) with some sort of additive (the shop did it), and there was no real fix.
then another mech did another oild and filter change, with another additive (10 w 40) and it was getting better....
the a few weeks ago i did the oil chage and filter, (5 w 40 synthetic), no additives, and its quite good now, only sometimes get ticking when i start the engine up.
i plan to keep these 5 w 40 synthetic oil changes happening about every 2500 kms, (every month and a bit) and hopefully the ticking will be completely gone.
i dont have any oil leaks either.
when i drain the sump and the filter of oil, how much is meant to go back in?
thanks a lot guys.
1 - 20 of 95 Posts
