Guest
·Are the passenger window switches lighted? I know in my car they aren't, but in later years maybe they are...
Sorry to break you, guys,GoldenCoupe said:Are the passenger window switches lighted? I know in my car they aren't, but in later years maybe they are...
Thanks Mike! I gotta replace the drivers side one anyway, so I will do it then!MikeD said:
the passenger window switches light up - only KA8 models. The old Legend models (KA3) haven´t this feature !!!
To Lee !!! Can you change the color?
YES, you can it. The inner of the switch (behind the visible plastic glas has a small blue plastic frame. That´s for the color. The only, what you do is, after you´ve removed your switch from the door panel, it´s possible, to pull out the caps from the switch. After this, you can push out the small pastic glas.
That´s all !
Mike
