Does anybody know anything about devcon liquid aluminum. I came across a diy for closing the waterjackets with liquid aluminium. It looks like a good idea but i cant find wat heat it will stand
well most of the liquid metals are not bad, i've used the 'chemical metal' before on my intercooler, work'd fine, and still is (4yrs on)
liquid goop
Hi, is it an aluminum filled epoxy? Probably, I have used devcon steel filled epoxy, it is much like jb weld. I remember looking at devcon's literature and they had epoxies filled with all sorts of different metals, stainless steel, titanium, and some others. I think maybe their jb weld equivalent was called liquid steel but in a larger package the same product was called steel putty.
JB weld may do the trick for you, it is durable stuff and I think it would take the heat ok. Sometimes it helps to warm it with a hairdryer, makes it thinner and thus will seep into crevices, also heat will speed up the cure. I have used it with bits of fiberglass cloth with excellent results.
However, I think the radiator trade uses some sort of glue to effect aluminum radiator repairs, maybe look there.
good luck, let us know what you discover
Jay
Yeh it is the aluminum filled epoxy. I talked to a mechanic and he said he has used it gearbox repairs and it is quiet strong and should take the heat. So im thinking when i get that far im going to give it a go and save a whole heap of money in the process
