1. The sway bar attachment you describe on the lower arm (with a hole and not the flange) is like that on my '87 coupe. IIRC, the flange arrangement is on the sedans.
2. Did you change the locations of the radius rod adjustment nuts at (No. 2)?
3. Typically, before final torquing tightening the fastener at the lower arm pivot (No. 1), you do this with the weight of the car on the suspension. You want the bushing to not have any twist in the rubber with the suspension at normal ride height.
There are only two alignment adjustments for the front end - caster and toe. Camber can only be measured. If it's out of spec, something is worn or bent. Anytime you do front end work or parts replacement, the alignment should be checked and adjusted. You should have a 4-wheel alignment done.
The rear suspension is adjustable for toe, camber like the front is measured but not adjustable.
It would be worth the time and money to have them align or tell you what wrong. At least you won't be questioning what's wrong and you won't have to keep throwing whatever parts are still available, at it.
