I have a 1990 acura legend sedan and I am pretty sure I know what I am doing when I am installing my springs but I was wondering what are the major hang ups and problems that I should be aware of before I begin the installation.
I was also wondering if the installation in the front is the same for the back.
Fronts and backs are significantly different. I fronts require a spring compressor, the backs kinda just fall out. Make sure you have a manual.
The only problem I had was maintaining the alignment of the mounting plate with the alignment tab while tightening the lock nut at the top of the strut on reassembly.
would anyone know the size of the lock nut on the rear strut of the 90 legend
Ya buy new struts for the rear and try to replace the old ones and you cant tighten them because the factory strut has a welded on nut. Please tell me Im not the only one with a factory stut that holds a nut
