1 - 2 of 2 Posts
I need to replace the maplights in my dome light console (near windsheild). I've tryed prying gently but I haven't figured out how to get to the bulbs. Does anyone know how to get the cover off?
Thanks,
you should bable to see a small slot for a flat head screw drive it fit in. You only pry off the lense for the dome light, if your talking abou the dual lights right next to the rear view mirror, your suppost to pull out the whole thing, you take one side partly off then pry off the other side. And to get off the bulb i would grab some pliers and put some coushion around the tip's and grab on to the bulb then pull the striaght off.
1 - 2 of 2 Posts
