1 - 2 of 2 Posts
after replacing the upper radiator hose ... a lot of coolant was lost due to having to take out the old hose (ovbviously)....but until now....i dont see a very drastic change with my coolant resevoir ... i thought it would uses the coolant in the resevoir since a lot of coolant was lost when i took out the old radiator hose
i dunno much about engine stuff so can someone tell me whats up ??
Is your car temp running at normal? I would try to fill up the cooland right at the radiator when the car is cool. But you shouldn't be loosing that much coolant when you are just replacing the top radiator hose.
1 - 2 of 2 Posts
