1 - 9 of 9 Posts
HELP,
Lately my 94 L sedan has been actin up. I put a custom intake on it and i think it may be getting too much air at idle. When i shift it in to neutral, even after it is fully warmed up, it will raise RPMS to like 1500, and sometimes it will go to 2500 and then drop to 1500 and then go up and down between the two. it is freakin me out, and it doesnt do it all the time. if i drive on the highway, even for like a minute, it doesnt do it, but if i drive like 5 or 10 regular miles( in town) it still does it. and i cant figure it out.
also, when i turn on my heater, (we've had some wak weather), my heat guage goes slowly up to the red mark, and then drops back to normal. WTF
and my trunk leaked again. im about to get pissed, when i put my audio stuff in there it will get f ed up. damn i gotta find that leak.
sorry had to vent.
please help with any of these problems.thanks
peace
tnelson
BTW leon, you can change my name on the legendary legendz mailing list from T. Nelson to Tyler Nelson, it looks kinda wierd havin everbodys first names and my nick name. oh well
Sounds like the throttle body might be gumming up thus causing your butterfly valve or choke to be positioned off a little. This will cause the computer to deliver more fuel and then lessen the fuel before it floods out repeatedly. thus causing the surging in RPM's. I had this problem on my 92' . What I did was but some throttle body/choke cleaner and use it is directed. A immediatly saw sludge run out of the intake and my surging was cleared. -Good luck
Hate to be the bearer of bad news but you might be looking at a bad headgasket. My 94 coupe just hit 135k and I found out I have a leaking HG cyl #3, after speaking with my mechanic I found that your heating/cooling system interfaces near that cly. Hence when you turn on the heat you start drawing more air in through the leak in the HG. Check your coolant overflow tank. If it is starting to fill up past max your engine is pumping the coolant OUT of the system as the gasses escape through your head into the system. Having warm and cold spots will trick out your ECU and that might explain the surge in idle, I have a very slight surge only 300 rpms, as well.
As for the trunk leak check your drainage channels (follow where the water would logically go) for debris like pine needles etc, usually its just plugged up somewhere.
Good luck, HG repair is around 1000-1500 depending on labor. :eek:
Discussion Starter · #9 ·
usually it only bounces when its cold, so it sounds like i have a problem like bang. btw i redid the colant line that used to run through the group of hoses that were connected to my old intake, and then i filled up the colant and did a bleed, like leon told me too, and i havent seen it bounce yet, but that was yesterday, and ive only had 2 starts since then, gonna go start it cold now, and see what happens.
i also have had a small amount of sludge in my intake(found this out when i took it off to do the colant mod), so i my throttle body is probably gummed up, like you said, somebody please tell me where to spray the choke cleaner and also what to get(brand).
Thanks for all the help, dont think i have a bad headgasket, but thanks, btw, what are the signs of that.
thanks
peace
Tnelson
1 - 9 of 9 Posts
