Exactly. Getting at the door speakers requires revoming the door panel to prevent breaking anything (ie, the grills).aiznpride said:i pretty sure the door speaker covers were not meant to come off at all. if you try to take them off, u'll break the tabs and won't be able to put them back in. that's probably waht happened. in any case, a little epoxy or crazy glue should do it. i used epoxy cause it's very strong once it's dry.
you can buy it at any harware store for like 3 bux.
-j
