Acura-legend.com banner
1 - 20 of 33 Posts
Discussion Starter #1
This is the work I have done since I get this legend to bad two weeks some one hit my bumper but I think still looking good.
Sent from my iPhone using Autoguide
Discussion Starter #3
Do you guys recommend to use a after market intake it runs good but I want little more power for my Type ll engine
Fut RIP
Not a bad looking legend and that looks like a easy fix on the front bumper. Cold air intakes they are about all the same.
Moderator
I have to ask, are the hood scoops functional? Any intake with a high quality filter will do, I have some tubes FS.
That is a sick legend! What body kit is that and what hood scoop is that as well?
Sent from my Autoguide iPhone app
Fut RIP
its a cyber kit
Discussion Starter #9
Yes cyber kit the hood think is not functional but with some help I make it work
Fut RIP
They said type ll has some thing around 230 hp did I get more hp with the air cold intake.
yea but not much hp 1-5 hp if even that much. yes the type 2 has 230 hp and the type 1 has 200 hp.
Discussion Starter #12
JD" what type ll is al about it is only 30 hp can you please tell me and where I can find a PDF manual for my legend
Fut RIP
Fut RIP
The type 2 motor has better heads with bigger valves and the intake has better ports for more air flow then the type 1. The type 2 came in all coupes 93-95 and was also available in a sedan in 94/95 but only in a gs modle the gs are rare.
Fut RIP
JD" thanks man for the info
It also has better ecu to control this and dual piston front brake calipers with bigger rotors then type 1's do only on the front.
Discussion Starter #17
If I get this right the 94/95 sedan models are only GS or there some LS too
Fut RIP
In 94/95 the only way to get a type 2 motor from factory in a sedan is in the GS model but there's L and LS models but they don't have the type 2. GS sedans are rare there aren't a lot of them out there and the gs 6 speed is the rarest of all sedans
Discussion Starter #19
I will post some pictures of my legend and maybe you can tell what kind of legend I have I that I was having the LS models all the parts that I have in my legend are LS. it that can be a problem if my car is GS
Fut RIP
Ok post more pics if you look at my thread in this area project FUT that's a 94 GS 6 speed! The gs also has a 91-93 grille but the chrome trim around the grille is painted to match the car color.
1 - 20 of 33 Posts
