Acura-legend.com banner
1 - 9 of 9 Posts
Cassis Red Pearl
Discussion Starter #1
I'm preparing to re-install my OEM radio and I just noticed a wire near the harness that is not plugged into the plug. However, the plug is not missing a wire coming out the back of it. Also, I looked in my factory repair manual and can not find where it might go to or what it is for. I feel its probably for some option, but I never noticed it before and just thought I'd see if anyone knows about it. Its a bluish-grayish wire with the typical silver dots along it. I'm trying to include a picture here.
Cassis Red Pearl
Discussion Starter #2
Terrible Feedback
So, I plugged in the radio just to be sure everything was working, got this terrrrrible feedback. I think it may just be because I don't have the radio bolted in, which I guess grounds it, but I'm hoping that wire is not a ground wire also? No one knows??? I see this thread has gotten some views but no replys. Am I just crazy???
Cassis Red Pearl
Discussion Starter #3
Figured Out One Part
Well I figured out that the blue wire is to my steering wheel controls, which pisses me off . . . . I always wondered why they didn't work! I still don't know why I'm getting such bad feedback, I get less now that I moved the ground to where the factory repair manual suggests it should be. But less is not good enough. Anyone else have trouble with feedback like that? I seem to just be posting for my own benefit . . .
theres a blue plug that goes into the back of the radio in hte separate plugs, thats what the blue wire is for.
You need a real solid ground.btw I have that blue wire with the plug connected. Pm me your address,I'll drop it in the mail for you.
Mark.
be more specific about the feedback your hearing. do you hear it when playing a cd or just radio.... or is it only if the engine is running... or is it literally all the time.
Cassis Red Pearl
Discussion Starter #8
Update
Turns out the "feedback" hasn't changed at all, as I thought it had at one point. I figured out that if I unplug the plug on the amp for the back speakers it stops. I even swapped amps to see if that changed anything -it didn't.
The "feedback" is a constant high pitch beep/tone. Its not a squeel it really sounds like a constant high pitched beep.
Occurs when the key is on -position II- and when the car is running. Occurs both when the radio is playing, and a tape. Haven't been able to play a CD yet, I actually just got a CD changer and haven't f*d with that yet because of this situation.
I have the ground wire hooked up as the factory repair manual suggests, with a brass screw even -I don't think grounding has anything to do with it. This "feedback" (if thats what it is) is eminating strictly from the rear speakers.
I am so aggravated. I feel like I've tried everything. I know that blue wire has nothing to do with it, thats just for the steering wheel remote. I swapped amps. I've moved the ground wire to every possible location, I know I have a good solid ground. I took the driver side rear 6x9 out and inspected the connections, everything looks solid. I didn't look at the passenger side yet, guess I'll check that tomorrow, but . . . I'm not hopeful about that. I hope its not my head unit. I'll be pissed.
Maracura91, I'd love to get my hands on that plug, I'll PM you.
1 - 9 of 9 Posts
