Hey Guys I have a 1991 legend coupe with the type 1 engine. I have 162,000 miles on my car, and my valve seals are leaking, so I plan on removing the heads to get the valve seals replaced, and replace the water pump timing belt ect... while im in there. But I found a jumkyard that will sell me type 2 heads and intake for $170. My question is, is it worth the truble and is there anything else that I need. I would realy appricate your advice.
170 for the intake and the heads is a good deal...just port N polish and you will be set. totally worth it since you will have the heads and everything off anyway. just remeber to use OEM gaskets, waterpump, thermostat and all.
and while your doing the heads, talk with telion and have him get you a chip for you ecu. type 2 intake and heads with a type 1 tranny
