I need picture and someone who knows how to, or
how to replace the clock spring..
Never had a haynes, how does one do this? I'm going to pull the clockspring for my car to sell this week.1_Hot_Legend_L said:Air Bags aren't a sensative as you think. If you have a repair manual for your car it tells you how to disable the Bags for servicing. Just follow those instruction and you won't have to worry about deploying the bags or setting off the blasting caps in the seatbelt tensioners.
Later!
Lenny
That's right, Jeff. No wonder why. All my DIY's and threads got deletedmorbo said:Actually, if you did a search you will find a DIY. MikeD wrote one up.
Looks like the thread is missing, or the pics are gone I can't find it.
Ok I did it. Man this needed 3 hrs to write it. Hope you all can read itMikeD said:Time to re-write it. Please wait if possible. It needs a bit time because of my bad English-Mike
MikeD strikes again!MikeD said:Ok I did it. Man this needed 3 hrs to write it. Hope you all can read it. Here are the links... SRS Airbag Removal / Steering Wheel Removal. More DIY's will follow, but please gimme a lil bit time
You guys need only some min's whereby I need several hrs
-Mike
... and Jeff pulls throughmorbo said:MikeD strikes again!
You need a Haynes? I have one for you. But I'd suggest you to take a Helm. Jeff, please PM me. It reminds me of a question I have. Maybe you can help me :bowdown: -Mikemorbo said:Never had a haynes, how does one do this?
Exactly Steve. I forgot it to mention. The reason is the "Self Locking Nut" and its synthetic material, what prevents a self loosening. Once it got removed, this nut should always replaced. Thank you, Stevestevieray said:One helpful little hint that I found out last week---when you remove the steering wheel nut, go to the dealer and get a new one to replace it.
No problem, Jeff. If you want you can get all my manuals I have. Gimme a call and tell me what you want to have, and I put all .RAR files on my server. Should be no problemmorbo said:I'm parting out my Legend Mike, a Haynes or helms would be useful, but I can't find one or afford one really.
PM sent.
