1 - 16 of 16 Posts
amy one what is going on i got sony amp and after like 5 min its so hot i don't know what is goign one does eny one know what is reason ?
and what is diffirend between Hi courent and Hi Voltage ?
Thanx
no i just hooke them up and i don't this i did something wrong every thisn is hooke up right thay just get hot in like 5 min
do u have any idea what could be rong ?
thanX
how are they mounted? if the heat fins (usually the top side of the amp) are facing past 90 degrees downwards (such as mounting them on the back of rear seats) heat can build up and kill the amp since the heat fins perform most effectively when heat can rise away from the amp. I had this problem once.
Otherwise, hope you have a warrenty...
i don't have anything alse in my trunk beside the one amp
and the amp is on the middle of the trunk
is can be anything wrong connect or somethign thet amp geting so hot ?
· Premium Member
Serious questions, where is your ground connected to metal? How good is your power connection to the battery? What guage wire are you using? These are the common leads to overheating amps. Check your connections and make sure it's done right.
if the amp is moutned properly and just getting too hot, it just may be its not getting enough air across the heatsinks.
I have a pair of new cage fans designed to cook amps in cars if youa re insterested, they are about 2 inch radius rans, like a big over size computer fan, you moutned one on each side so its push pull across teh heat sink, and it should take care of the overheating problem.
30 shipped for both...
b
Discussion Starter · #10 ·
i went to best buy and i bought the kit for 130$ and it got everythign it for 2 amps
i hook up only one for right now bc i don't have subs and the all speakers go to amp and i got 4 wires form amp to the cd player for each speaker
r u gous hook the wire directly to the batery or to the box with all the fuse( right next to the batery ) i plug in to this box
· Premium Member
just make sure you have a good ground. There aren't very many good places to mount a ground. check all your connections, most amps heat up because of a loose connection. Also, you should hook up your power wire directly to the battery with an inline fuse.
Discussion Starter · #12 ·
hold on i post some pic for u how did i do that
and thanX for all your help
Discussion Starter · #16 ·
the ground is on right in trunk and there was few wires hooke up to the ground so i hooke up the amp grund with them too
1 - 16 of 16 Posts
