1 - 2 of 2 Posts
here is the situation,
I just bought a one piece headlight for legend sedan 4 door. I am planning to use the JDM fog light as a driving light along with my low beam. my question is on how to wire the fog light such that the fog light can be on whenever the low beam is on. so i browse to the legendtuner.com and found the following link
http://home.mchsi.com/~kojih2/upgrades/bumperfogs.html
in the tutorial, it takes the current from the corner light and use the relay to pass it through the bumper light so the bumper light will have the same effect with the corner light. my plan is quite the same by taking the current from the low beam of the headlight and use the relay to pass it through the fog so that my fog will on whenever the low beam is on.
do u think this can be done?
how about the fuse? do i have the same rate or larger rate amps for the fuse? thanks
1 - 2 of 2 Posts
