I was wondering if some of you guys can give me some symptoms of a bad oxygen sensor. I was told i need new ones cuz my car has been shaking alot, and now i have very poor acceleration. whats your diagnosis
Yeah i just got plugs, wires, and distributor done this week and its still like this. Im goin to autozone tomorrow so they can put it on the computer to see whats upBefore you finally decide to change the O2s .. make sure that you check/replace the fuel/air filters, distributor cap, rotor, plugs and wires first... it would suck to replace the sensors only to find out that it was faulty plugs....
within the week i got the plugs, wires,and distributor cap put in, this problem started about a week or two before this was done. There are no smells and it shakes in park, drive, and a whole lot in reverse. doesnt seem to matter if the car is cold or hot. when i accelerate to a higher speed i hear a pop pop pop.i got some questions for you though to figure this thing out
Yeah i live in the wicker park/ humbolt park area. The plugs i got are Denso, and the wires i got were Advan-tech, I asked the guy at Maverich autoparts for the stuff for a tuneup and this is what he gave me, he said the stuff would be good. I really appreciate ur guys help with this tooand i see your located in chicago....
It sounds like you just needed a full tune-up chitownlegend... replace fuel/air filters as previously suggested, pcv valve is important as well and also add some fuel injector cleaner in your gas tank on your next gas fill up.chitownlegend said:within the week i got the plugs, wires,and distributor cap put in, this problem started about a week or two before this was done. There are no smells and it shakes in park, drive, and a whole lot in reverse. doesnt seem to matter if the car is cold or hot. when i accelerate to a higher speed i hear a pop pop pop.
Actually the popping sound is coming from the front of the car. today i put the fuel injector cleaner in and i noticed a bit o a difference but is still shaking. Could it be that i need a new fuel filter?the poping sound, is that comming from the exhaust? how loud is it? could be back firing or sputtering indicating is is a timing or ignition problem.
tried that and i guess it only does it when i drive the car. UPDATE: the car is even worse now than when i first posted, ive done nothing different and now there is a sound coming from the muffler, idk if its backfiring, it just sounds like its underwater or something. And the worst part is that i filled my tank up yesterday and today i only have a quarter of a tank or so. it ate up all my gas. I have no idea what is goin on now.while the car is running in park pull the accelerator cable under the hood to make it rev up and see if you can pin point exactly where that popping is comming from.
The air filter was changed about a month or two ago, way before any of this started goin on. and what about my fuel filter, is that not an issue at all, i just bought one just in case, when i put it on, ill post if there is a differencealso replace that air filter.. both of these should be under 20$
