Sorry guys, I don't always get "reply to post message" as an e-mail. If you can PM me just to make sure I get the message I would really appreciate it.
**Eibach started being produced 50 yrs.ago by Heinrich Eibach in Finnetrop Germany. Springs are created from the finest alloy wire. Cold wound on precision CNC equipment, heat tempered, end ground (when neccessary), shot peened , pre-set for fatigue resstance , phosphate treated and powdercoated for corrosion. ******EIBACH makes a Pro-kit for the Legend1987-1995. 87-90 the drop is approx. 1.2 in the front and rear. **91-95 it's approx 1.1 in the front and 1.0 in the rear.********
H&R was started by two germans Werner Hein & Heinz Remmen(H&R)Springs are precision wound using only the highest quaility German spring steel avail. On-time tempering to realign the molecular structure for long term resilience. Shot peened in and out, to increase service life > 200%. Every spring is pre-set using the exclusive -Super Blok- system, which cycles the coils so the springs can never set or sag. Finally, a flexible an durable finish is applied
owder coat.**** H&R makes a STAGE 2 sport spring for the KA7 and KA8. The approx. drop is 1.5 in the front and 1.4 in the back.********
I personally ride on the Pro- kit and love the improved handling. I know their are alot of owners who have the H&R 's who will say the same. I don't know if you can really feel the difference between two quality springs. So, I'm safe to assume that preference and the drop height will help you decide.
I think the Eibachs are low enough I always mange to scrape that shiny new Remus no matter how much I slow down.
I hope I answered your question, and If your still awake after the History lesson I need zip codes to be exact on the total..
Mr. Wholesale
