My throttle Position sensor was cured by cleaning and probably luck. I did check all the connections So I am happy about that. Getting ready to smog it by doing the simple things like new plugs and wires as suggested here on the forum. I put in 10-30W for oil. BUT..............
I did get another engine light after fixing the Throttle sensor. It blinked 8 times, and according to the codes it says TDC sensor or circuit (Integra). Mine is an Acura Legend so I assume it referring to the TDC sensor. It does go off though after I restart the car. It is intermittent. According to Chilton's, the TDC or Crank angle sensor is a real pain in the .... to do. Removing timing pulley, etc..... Is this the real problem? Is there something else I should check before? Anyone have an idea what is wrong.
When I reset the ECU by pulling the alt sense fuse for 10 secs, the engine light doesn't come on for a while. As soon as I stop and go to an idle at a light, it will come on if Im stopped too long. I think Im going to try to smog it and hope the light doesn't come on during the test. The problem is the smog is due now. It's an instant smog fail if the engine code comes on. So any help would be appreciated. As soon as I get it smog ok'ed, then I'll be able to dig into this car and fix it. I like the car. It kicks .... on the road. I'll begin refurbishing it slowly as time and $ permit. Thanks again. Great forum.
