New to Forum
735 Views 4 Replies 5 Participants Last post by  OrangeGen1
Hi, I'm new to this forum. I have owned two Acura Legends. My first was a '87 two door coupe. I currently have a '90 Legend 4dr. I love the older Legends. A mechanic at MotorCars Acura said do not get rid of car. The first generation of Acura's were the best build. I have changed the oil regularly and the ATF. He did mention this: double change the ATF. Change once, drive it a little, and change it again. Total Qts=7.
I also own a Jeep. This thing is a piece of crap. There is always something going wrong with it. Here's a great difference in design: to fix a/c pull the dash with five hours labor plus parts. '90 to fix a/c and install new evaporator pull the glove box. My '87 had 300,000 before selling. My '90 only has 270,000. I do not let anyone work on it except me. I've done timing belts and most maintenance. Currently, I will change front upper control arms and lower ball joints. I will also add some new axles. Both Acura's are the best car I've ever owned. I do not work on this one without the service manual.
With my '90, I will replace evaporator this spring since I'm in Michigan. The part is $55.
One question: the car will not shift into low gear on auto trans. I do this manually. There are three solenoids on top of tranny. Could on of these be bad? Please advise me if you may know.
Welcome to the forums always glad to see 1st gen owners around.
Welcome
