as I'm having the first problem with our RL so far and I'm bummin'.
We have a 2000 that's just lost power to the stock Bose system, interior lights, and possibly cruise control. I haven't driven it myself yet (wife's ride) so I'm not sure but the indicator doesn't light when I depress the switch.
There are no fuses in either box that are labeled as handling all these circuits, and I've checked all fuses in both boxes and they're all good.
Is there a plug on the harness somewhere that handles all these circuits that someone might have kicked? I haven't found anything yet but I haven't spent much time at it. I'd rather spend it here than upside down under the dash. :(
TIA,
Steve
The stereo and the interior lights share the same fuse, fuse 57 (20 amp) in the underhood fusebox. The lighter socket also shares this fuse. I've seen loose change stored in the ashtray fall into the lighter socket and blow this fuse on many occasions. You might want to double check that fuse just to be sure.
