Here's the NO HEAT. I've check the fuse no luck there. When I turned the dial I hear a click but no heat blowin'. Any suggestions please it's gettin cold here and I can't keep to the windows clear. Help me out fellas please.
DaGurl is freezin'!
Does your engine temperature gauge still work? Does it go up and then drop down again?
If so, it could be thermometers, or possibly even something with the radiator (ie: bad cap - no pressure, not enough fluid...)
