1 - 8 of 8 Posts
Hi folks,
I have a 1992 Legend Sedan LS, and after the BHG was repaired I was told to ONLY use the Green Anti-freeze. I did search and I have read this thread...
"TYPE 2 COOLANT New and Improved"
http://www.acura-legend.com/vbulletin/showthread.php?t=57673
....but it seems inconclusive.
Lately I cannot seem to get all the air out my cooling system, so I am having the problem where at idle (when warmed up) the RPMs cycle from 500 to 2000 RPM (approximately). A few other symptoms have led you folks in the past to suspect a leaking Power Brake Booster as the cause for the air getting into the system, but I really don't know. In the past I could follow the air purging procedure and get the idle stable, although in a few days or weeks the cycling would return.
I wanted to make sure that if I lowered the level of my coolant too far, I could top it up, so I went to buy some more of the Green anti-freeze. But at a local Honda dealership (there are no local Acura dealerships) the parts guy said there is no more Green anti-freeze, that I should be using the Blue anti-freeze.
Is this true? Does anyone have any more information or opinions about this? Please comment! :-D
The level in my overflow/reserve looks fine, by the way, but it is awfully "dark"! :-O Not the bright limey green I was accustomed to, but more of a brownish green! I didn't see any "slick" but I wonder of the color indicates oil in the coolant, or just rust or old age or something! :-(
Although my temp gauge still sits faithfully unmoving on the second index up, I wonder if my HG is leaking/blown again. :-( I guess I could have a compression test done. I'm due for a smog check, which was one of the reasons I'm trying to stop the idle cycling, but I don't know of a trustworthy mechanic here in Santa Cruz for the compression check.
So is it okay to use the Blue Anti-freeze or would it be better to track done the Green? Is the Green still available?
Any ideas, comments or suggestions would be very welcome! Thanks for looking!
- Thomas
· Victory is fleeting...
I don't think Honda would change the formulation of their anti-freeze...the important consideration is whether the anti-freeze is silicate-free. Maybe call Acura of Augusta, tell them you are from this board and see what they say about anti-freeze? Jason should be happy to help, he's answered a lot of my dumb questions in the past.
Thanks duck! I'll call Jason.
Any other opinions, comments, ideas or suggestions! :) What do you all think of the dark green coolant? How about my inability to get the idle stable?
Thanks for looking!
- Thomas
Discussion Starter · #8 ·
I called the car's original dealer back in Connecticut, Executive Accura, and they said they still have the green anti-freeze if I really want it, but that the blue would work fine too. I'm tempted to get more of the green for now, so I'm not changing the color I look at.
I guess when I do flush, I'll switch to blue! :)
And sorry for the huge SIG, I don't know how it got switched to that big one, it should be about half that size! (There - I have fixed that!)
Thanks for the comments and help folks!
- Thomas
1 - 8 of 8 Posts
