Just bought a wrecked 91 LS with minor front end damage. It has been sitting up for about a year!! Other than needing a new battery, everything appears to work. Tried to jump start it but got no start!! meaning no starter action, just a hissing noise comming from under the hood. Anybody out there with some tips on getting it started??? tricks or anything!!!!!new to the legend line...NEED HELP!!!!!!
Good luck
Is it fully loaded? if it is, then, go to Sears auto store, get a "DieHard" Gold battery costs $80.
Premium Member
try these in order:
1. borrow a battery from another car. make sure it's fully charged and install it in the Legend. Or buy a new one if you want to.
2. check the oil. add a little bit even if it's full (1/4 qt. at the most).
3. check all the fluids and make sure they're up to par.
4. put the car up on jack stands and tap the starter lightly with a hammer. Check wire connections there also.
5. check air filter.
6. it should start after this.
post after you do these things if it still doesn't start.
