The 88 Standard Sedan we have sitting out there has it.88_acro said:my 88 sedan had it but not on my 87 coupe that sucks if there is nothing i can do![]()
yah thats what i thought but do you think i can get a column off of another car and put it inpacallen said:I believe the earlier G1s had a choice of either an airbag or a tilt wheel function... That changed in 88 or 89 when the cars could have both.
My 87 acura legend coupe ls has srs (suplimental restraint system) an air bagjno2968326 said:no 86 or 87 had an airbag.acura started drivers side airbags in the 88 LS model only(USDM).
Yeah it sucks that the 91-93 G2's didn't have tilt. I've thought about using a couple washers as shims between the steering column and dashboard support beam to lower the wheel a little. Haven't tried it yet, just an idea I was considering. Might be able to do something similar on G1's. Wouldn't be able to lower it much but every little bit helps.1_Hot_Legend_L said:My 91 Sedan don't have tilt but it has telescopic! What is up with that one? my 87 coupe had fully adjustable!
Oh yeah Im almost for sure you could do that...what I'd like to know, would it be at all possible to get the power tilt/telescope of a 94-95 L/LS and get it to work in 91-93 OR EVEN (long shot) a G1??88 acro said:yah thats what i thought but do you think i can get a column off of another car and put it in
