Noid light
1139 Views 3 Replies 4 Participants Last post by  KA4 to FG2
1986 acura legend 2.5 auto.
checking the fuel injection pulse's does anyone know when you turn the key on to prime the pump should the noid light kick on for a second to prime the engine with fuel?
When I checked on my Maxima it didn't light up when the key was in the II position only. While running it did flash/illuminate.
Sorry I've never used a noid light to test injectors. I wouldn't see why an injector would pulse and flood the engine with gas if the ignition hadn't been told to fire.
A very easy way to test injectors is with the car idling. Disconnect each injector, one at time. There should be a very noticeable change in RPM's or idle with the injector electrical disconnected.
Some engines do pulse the injectors for cold starting purposes.
Sent from my Autoguide iPhone app
