noisy tick that won't stop
932 Views 2 Replies 2 Participants Last post by  squirrel30668
OK so I just bought a 1990 legend. It has 260,000 miles. Still runs like a beast but has this fast tick at all times that gets worse as you accelerate. My father suggested valve risers but I know it could be a lot of things. On a side note as its idleing it drooss down to almost zero and about cuts off then comes back to life. Also sometimes I have to pat the gas on a cold start. Any input will be appreciated.
Lifter noise is a typical thing for the G1. But what's happening is the valves are getting stuck when the engine is cold. They'll loosen up once the motor is hot. There are some stuff you can do like adding ATF into the crankcase since it had detergent to clean stuff up. I need to look into that first so hang on a bit while I confirm on that.
The idle issue, where does the tach needle sit? Things you can try doing is cleaning the throttle body, change air filter, and adjust idle screw.
Well the ticking actually stays the same. Its actually quiet the first few seconds after it cranks. It idles around a grand usually. Sometimes it does like to hang out around 800. Also just recently noticed the clutch acting funny in low gears like first and reverse. The pedal is nice and firm and smooth till it gets to the floor then it starts to feel "notchy". I can drive a stick well and every time I leave from 1st or start to back up, I almost choke it out
