Please don't move this thread!! I'm not getting any answers in the sticky.
I've done searches and posted in the "Does your car overheat?" sticky, but I only got one reply from Jetdoc. It's been about a week or two now and my car is just sitting there in the driveway. I'm hoping someone can tell me what might be wrong with my car. HOPEFULLY it's not something really expensive.
Here's my old post:
So yesterday (Monday) morning I drove my little sister to school (it was freezing outside...about 30 degrees F. and I guess my car was all frosty from the night before) and on my way home, I noticed my temp needle was ALMOST go to "H" and pulled over right away (it was rising pretty quickly). I popped the hood and let my car sit for about half an hour.
****Side note -- incase it matters: I just switched to synthetics (Mobil1 10w-30 on Sunday and a different oil filter). Can this be the cause of the problem, or do you guys think it's just a coincidence that my car happened to overheat the next day?? I really don't know at this point, but I'm leaning towards no. It HAS to be something with the weather or my radiator, am I correct?? ****
When I looked around the radiator to check for any leaks or loose caps, I saw nothing. But near the back-up reservoir (and the area below it), there was coolant all over. Whatttt'ssssssss goingggggggg onnnnn with my carrrrrrr?!?!? Anyway, I opened up the radiator cap and filled it with some water (it only took in about 1/5 a gallon and then was full). I also poured in extra water into the back-up reservoir. When I drove home (and for the rest of the day), everthing was fine. Freeway...city...NOTHING. It did not act up once after yesterday morning, so I'm thinking, 'Okay, maybe I was trippin' and didn't close the cap tightly' even though I'm certain I didn't mess with it before.
FYI, later on in the afternoon I drove my car to work and around and it didn't even come close to overheating.
Well just a while ago, I was on my way home from dropping my little sister off at school (it's about 30 degrees outside...same deal..frost on the car, etc...I let my car warm up prior for 4 or 5 mins.) and my temp needle rises hella quick again!! Keep in mind that I've only been driving for about 10-15 mins. I pull over, repeat everything and find that there's coolant all over the back-up reservoir again, but I don't know if it's seeping through the opening where the lid is or exactly where it's coming from. This time, just to check, I turned my car on again (a minute or so after I pulled over) and watched the needle and its sitting at normal again. ?? There's coolant all over the same spot again. I let my car sit for a good 30 mins. before pouring water into the back-up just to be safe. When I drove home, the needle didn't go past where it normally sits and my car seemed okay again.
What do ya'll think? What's your put on this? LOL...I apologize for the length of this post, but I really am stumped and a bit flustered. At least I have an excuse to move MY car into the garage now, huh? Okay, help please!!
Lately (ever since those two times my car started acting up), my car's been overheating within driving a couple of miles. I'd say about a mile or two into any trips, my needle starts rising. I'd pull over and coolant is all over the reservoir again and I'd have to fill it up again. I've put in anti-freeze and still no fix. My hoses are soft when my car's at normal operating temperature. It doesn't seem like there's any pressure in my radiator...I even replaced the radiator cap and thermostat. When it overheats, the reservoir fills up with coolant and spills out then it starts to overheat. No matter what I do, it doesn't overheat at idle. When I turn my heater up, the heater blows out hot air, so it's not the heater core, am I right? How do I figure out what's wrong with my car? Any diagnosis? I also tried bleeding it, but that doesn't seem to be helping at all. I can only drive about 2 miles max. before my needle starts rising to hot.
I also need to take my car to the police station to get them to write my ticket off, but I know my car won't make it. I have till the 22nd! Alright, thanks to whoever reads through this lengthy post. I'd appreciate any serious feedback. Thanks, ya'll.
Here's my old post:
