The center bore of the front NSX rims are the same 70mm like our Legend for both the 15" 91-93 rims, and the 16" 94+ rims. It is the rear NSX rims that are 64mm. You can use either front set all around on the Legend. Both front NSX rims are 7" wide with a +55 offset.WhiteLegend said:Also they center bore of the front wheels are 64mm, you need to bore that out to 70.1mm to fit the Legend. The rear wheels have the same size center bore as the Legend.
