I cannot post a link here. But I googled "OEM Honda bearings" and took the first site. See if that is useful or others below it.
The trouble is the legend bearings are unique (so I can't use any other OEM bearings) and most honda OEM parts dealers say discontinued. I just figured maybe someone knew of someone who might have some sets still around.I cannot post a link here. But I googled "OEM Honda bearings" and took the first site. See if that is useful or others below it.
I'm asking about the bearings, not the bearing caps. I've rebuilt too many honda engines to count, and one of the things I value most is OEM Parts (especially rings and bearings), so I like to find those first if I can.When I rebuilt my motor, I bought a refurbished crankshaft that came with a set of the connecting rod bearing caps. So you'll need to call around a shop that does refurbish crankshafts or a parts store since they need to measure the journals on the crankshaft to give you the correct thickness.
