1 - 20 of 63 Posts
OK so my windows have always been kinda slow and crappy always sounded like the motor was about to die and when it was raining forget it I had to pull it up with my hand. I always thought the regulator was bad like everyone says, so the other day i took my door apart, took the regulator out and looked it over. Looks great a little dry but no broken or bent parts, so I lubed up the regulator tracks and gear with Lithium grease no improvement. Then I did something stupid and tried to put the lithium grease in the rubber channels that the window slides in. It worked great for a day then was way worse, not to mention lithium grease is petroleum based and will eat your rubber.
Then I found the real cure, I did some research and for a special lube called Shin-Etsu It is a special very low viscosity silicone lube. This stuff is only available from your Honda dealership and is what they use on all there seals. This stuff is truly amazing I cleaned my channels out got rid of all that lithium grease and put this in. WOW my windows now slide up and down effortlessly seriously like butter, my windows have never worked so well. Now ive only been using a few days so I cant testify on the longevity of the cure but from my research it will last for a long time and is very easy to re apply. This stuff can also be used on all your seals and will help extend the life of all your door seals. Its alittle pricey at 20$ a tube but it is well worth it for all you will slowww rolling windows try it out.
Bought it here
HONDA-ACCESSORIES.COM
good to know. in the 1 year ive owned my leg the front pass window has always rolled up twice as slow as the drivers side and the sunroof always gets a lil stuck when its cold outside. will keep this in mind if the situation gets any worse.
Yea i just sprayed silicone liquid grease on the rubber part after cleaing the sills and it worked great. I also used penetrating oil and WD40 those 2 sucked cuz they dried up so fast not like the silicone spary
Same thing with my window
On my 93 Legend I expirience the same thing with my window, but my window switch also make a buzzing noise. At times my left front and rear windows wont go down when I use the main switch. Can it be the main switch. Also, my seat memory button does not work. Are these two items connected with each other. Can someone help me please. Thank guys
SGM / Type F
Bought it here
Nice find!! I wonder if it would also work on weather strips in extreme cold conditions?
Great Find!! Thanks for the post OP! :) I'm sure this will help a lot of the member's out with the slow window issue! I'm def gonna use that if my windows start to slow down or I'll just poke the hamster who's slacking on the wheel to bring my windows up and down! (maybe i should feed it?) :hide:
Well shit! If I had any idea that this was not well known! I put in the new channel runs and greaseem with them with this stuff last month. The story at the dealership is that they came out with this grease because of the problems with the channel runs with the legend but :confused: that's just what the guys told me. It works hella good though!
Discussion Starter · #16 ·
good info, i tried wd40 and it works fine but when i wash the car or it rain it washes away, but thanks for the good info ima go buy it now
NEVER use wd40 on rubber, WD40 is petroleum based it was eat rubber!
PS my windows are still working great and its been a few months sense I did this.
Thanks for sharing good info Roger :thumbsup: , my driver side window rolls up and down slow as hell. I wouldn't mind to buy this product.
I'm a look into this product. But what also works is the armor all wheel spray (clear one). It last for months, even when you wash your car. It sticks really well on the window rubber.let me know if anyone else has tried this to confirm that it works great. Thank you
1 - 20 of 63 Posts
