Hehhehe.......... you just removed the antenna wire instead of the power wire. Look around again, and you will see a plug that has power on it. Not that big thick black antenna cord.
It is plugged in by defualt ... on the stock radio, there are two antena plugs ... the mast and teh window. Unless someone disconnected the window one, it should work fine. Keep in mind that the window antena is not that great. Fine for city, but it sucks on the highway (use the CD anyway!)Sh0ck3d said:How do you use the "internal" antennae
