Does it heat up while you're driving or at a stop?
For the brake light, there's a tab that sits in front of the brake switch on the pedal assembly. Grab a flash light, move the seat all the way back and look up where the brake pedal goes and you'll see something like this:
Circled in blue is the brake switch. Circled in Red is the tab that pushes the switch in. If that's missing, you can get one fairly cheap at an Acura Dealership.
