Does the just the condensor fan come on when you turn a/c on or both the radiator and the condesor fan? If the radiator fan never comes on you can check the motor of the fan by using jumper cables to hard wire it to the battery momentarily. If it runs when it is hard wired to the battery, then you could have a problem with the switch. If it doesnt run with it hard wired to the battery, it is your fan motor. Both are fairly easy to replace.
